Which one of the following is not a generally accepted method for locally verifying that a valve is open?
A. Observe local flow rate instrumentation.
B. Check the local valve position indicator indicates OPEN.
C. Turn the valve operator in the close direction and verify that some movement occurs.
D. Attempt to turn the valve operator in the open direction and verify that no movement occurs.
Show Answer
Answer: D
