Why IP Rated Wall mounted cabinets?
IP rated Wall mounted cabinet provides an extensive range of fiber management systems (FMS) fully compatible with industry grade fiber adapters. IP rated FTTH series wall mount fiber terminal box is designed to provide quick patching, storing fiber terminations. IP rated wall mounted cabinets are protected from dust, oil, and other non-corrosive material. It is also used for Indoor/Outdoor applications and medium-size multi-dwelling units (MDU’s) for FTTx.
IP rated Wall-mounted cabinet integrates three main functions of fiber splicing, cable winding & storing, and interface management. The enclosure adopts good quality metal sheets & surface electrostatic spray technique, which is offering safety & good endurance performance. It is the ideal design for building & campus networking. [Wall mounted cabinet/LIU is designed to support fusion splicing or direct termination of the fibers. This modular enclosure provides cross-connect and interconnect capabilities for splicing and terminating outdoor cables & FTTH drop cables in the fiber access network. Our Wall mounts fiber patch panels are made with 16-gauge mild steel with corrosion-resistant seven tank process powder coating to provide excellent protection for the inside.
Applications:
  • Outside Plant
  • Mining & Military
  • Road & Rail
  • Ship to shore
  • Industrial Uses
  • Transmission boxes for substation
  • CCTV & FTTH Applications
  • Factory and automation applications
