Why is a Pressure Transmitter Installed Upstream of a Flow Transmitter?
Upstream of a flow control valve a pressure transmitter is installed to measure the operating pressure.
At times it is used for computing the true flow against the designed pressure.
Downstream of the control valve the pressure changes as the control valve open and closes.
